baseboard electric heaters
Old 04-09-19, 06:23 PM
R
My house is heated with electric baseboard heaters. I'm on a dual fuel rate with my power company so I have half of my heaters on a separate panel that they can shut off in periods of high demand. I noticed a couple weeks ago that it seemed a little colder in my bedroom at night but didn't think much of it. Yesterday though I realized that no matter how high I turned up the 3 thermostats that control the heaters on that panel, none of them kicked on. No breakers were flipped, and I tested them with a multimeter and all are reading as they should. I would think next to check the thermostat, but since there are multiple thermostats controlling the heat, that it's unlikely they all three would go bad at the same time. Any ideas?
Old 04-09-19, 06:42 PM
L
Received 181 Upvotes on 155 Posts
That really depends on how thermostats are wired.
I'd start with measuring continuity of TCO (thermal cut off) and resistance of the heater. It should read something pretty low probably around 10 ohms.
Since the heater is a simple resistance load, you can calculate expected resistance from your heater's rating.
R=V^2 / P where V is your heater's rated voltage and P is your heater's rated watt rating.
Old 04-09-19, 07:09 PM
Received 3,491 Upvotes on 3,134 Posts
Welcome to the forums.
Did you actually measure 240vAC with the multimeter ?
Old 04-10-19, 04:11 AM
B
Received 245 Upvotes on 217 Posts
How have you verified the bb heaters in question are not controlled by the power company controlled panel? Do the bb heaters in question have individual t'stats or are they controlled by an area t'stat that controls a power switch or switches?
