New Switch Trips Breaker
Old 04-11-19, 02:40 PM
C
Kitchen makeover included new receptacles and switches. As much of a klutz that I am, I figured even I could do this. Apparently, I was wrong. One of the boxes has a receptacle on one side and a switch on the other. They are on different breakers. The receptacle works fine. The switch controls the receptacle under the sink and controls the dishwasher and disposal. When I plugged in the disposal it tripped the circuit. Did I buy the wrong switch? Is it wired wrong? Two pictures below. . .although for the life of me I cannot figure out why they are sideways.
Thank you!
Old 04-11-19, 02:48 PM
L
Received 70 Votes on 64 Posts
Did you also replace receptacle under the kitchen sink?
Dishwasher receptacle should be always hot not controlled by the switch.
Often, half of the duplex receptacle is used for dishwasher and the other half is used for disposal and only this half is controlled by the switch.
To accomplish this, 12/3 cable is used and the receptacle is powered by 2 different poles.
Does receptacle for dishwasher/disposal have black wire on one terminal and red wire on the other? If so, you have to break a tab on hot side of receptacle. It is a small brass piece connected tow halves of the receptacle.
Also your switch should be grounded even if it was not done before. And you should wrap wire on the terminal clockwise. If you wrap wire counter clockwise as you have right now, the wire unwraps as you tighten the screw.
Old 04-11-19, 03:24 PM
Received 1,113 Votes on 1,033 Posts
When you post massive pictures..... the board doesn't know what to with them. Your pictures were 3000x4000 and over 3mb each. The board can only display about 650x650 and 80kb.
Old 04-12-19, 03:01 AM
C
Yes, receptacle under sink was replaced. I thought I did a straight swap, buying the same receptacle I was replacing and wiring it similarly. When you start talking 12/3 cable, breaking tabs, etc. . .well, I'm likely over my head.
Pete, sorry about the mega-photos. Damn cell phones. . .
Old 04-12-19, 03:58 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
That is wrong. The switch should only control the half of the receptacle with the GD plugged in. There should be two wires to the receptacle. One controlled by the switch. One always hot.
Old 04-12-19, 04:07 AM
L
Basically do this on hot side (brass colored terminal) if you have 2 different colored wires going to the receptacle.
Red one will be switched one.
Old 04-12-19, 03:20 PM
C
As pointed out here, the problem was the brass tab. Once I pulled it off, all is well.
Thanks, gentlemen.
Old 04-12-19, 05:44 PM
ray2047's Avatar
Are the G/D and D/W on the same breaker?
Old 04-12-19, 08:47 PM
C
Yes, both units are on the same breaker.
Old 04-13-19, 03:55 AM
L
It should bee on 2 pole breaker or at least handles tied together.
Old 04-13-19, 05:29 AM
C
My mistake. I just checked again and the disposal and dishwasher are on two separate breakers. As always, the help and smarts that are shared here is very much appreciated.
Old 04-13-19, 03:28 PM
L
If they are on 2 different breakers, are they right on top of each other? If not, it is illegal. There should be a handle tie so both circuits are turned off when you turn the breaker off or one of them trips.
It is multi wire branch circuit and could be dangerous if one works on the wiring without realizing it and finding associated breaker.
Old 04-13-19, 04:14 PM
C
They are attached and operate as one.
