No electricity in outlet's wires
I have a few outlets (1 main floor, 1 basement) that dont work in a house I just moved into.
The outlets look like normal outlets with 3 holes, no reset buttons or anything like that.
I put my multimeter into the holes, as well as to the 2 wires connected to the back of the outlet, and get 0 volts every time. The circuit breakers are all 'on' in the fuse box.
It seems like the wires are bad, but not sure what to do next.
Any help would be great as I'm a total electrical noob.
House is about 60 years old.
1st Have you turned off and on ALL breakers. Be sure to turn all the way off and on. Some breakers will look on when off.
Look around for a gfci outlet any place in house. Outside, in bathrooms garage, hidden behind furniture. Look at the last working outlet or first bad outlet for loose or backstabbed connections.
Turned on and off all the breakers, still nothing.
Theres a GFCI outlets in the house (they have the reset buttons right?). I pressed reset on the ones I found, should I try something else?
Im confused on this. Theres an outlet 10 feet to the left of this broken one that works fine, and another outlet 10 ft to the right that works fine. Both are normal, non-gfci outlets.
Welcome to the forums.
The GFI receptacles should have two buttons. A T for test and an R for reset. Press the T button to make sure it trips. You should hear a click. Then press the R button to reset it.
Could the receptacles be switch controlled ? That could be likely if there is no switched ceiling light.
The best thing to do when moving in to a new house is to go thru the house and make a list of what is on what circuit. The list can come in handy when diagnosing problems.
Your next likeliest step would be to pull the receptacle out without removing the wiring to visually check.
Checked the couple of wall switches nearby, didnt do anything.
I pulled out the receptacle and put my multimeter right to the wires. Got 0 with one fork on the silver screw and the other on the gold screw. Does this mean the wires are bust and probably not as easy as replacing the receptacle?
That is a receptacle and box that was installed after the house was built. It was cut in to the wall and screwed in. It is the end of a circuit or a stand alone receptacle. If that is on the first floor..... check the basement just below that area.
That looks like BX cable there.
