Electric Relay wiring
Old 05-03-19, 01:18 PM
R
I just got an Omron MY2NJ AC 110V relay. It has pins numbered 1, 4, 5, 8, 9, 13, 14 but I can't find what they are. Which are for AC in, which for load, which for switching?
Bob (RAC007)
Old 05-03-19, 01:21 PM
Received 27 Upvotes on 21 Posts
Here's a link to the datasheet, which has the pinouts. Not sure what the "J" suffix denotes, but it likely doesn't change the pinout.
http://www.ia.omron.com/data_pdf/cat..._7_3_csm59.pdf
1, 4 = Normally closed
5, 8 = Normally open
9, 12 = Common
13, 14 = Coil
Old 05-03-19, 02:02 PM
Received 4,154 Upvotes on 3,730 Posts
1-NC, 5-NO, 9-common
4-NC, 8-NO, 12-common
13 - 14 coil.
The NO/NC pairs need to be used with their own common.
If you are using it as a two pole relay..... you'd use 5 & 9 and 8 & 12.
Old 05-08-19, 04:10 PM
R
Thank you gentlemen. I did see the diagram but was not sufficiently familiar with electronic notation to translate it into NO, NC, Common and coil. Thanks also to the other moderators for making this forum possible.
