3 way bulbs (north america)
Old 05-08-19, 06:54 AM
A
the lamp is 10 years old.
work well
today the bulb stopped working on all 3 settings.
replaced the bulb which lasted a few seconds.
assume i will have to replace the socket. anything special i need to know?
thanks
Old 05-08-19, 07:03 AM
ray2047's Avatar
I once bought a package of regular bulbs and none lasted more than a few seconds. Tried different bulbs and all was fine. The first bulbs were just a manufacturing error.
First look inside the socket. Do you see green corrosion. If so clean it up and try a regular bulb. It should work on one setting and not the other. If successful try a different brand of 3-way bulb.
Old 05-08-19, 07:32 AM
A
Received 86 Upvotes on 78 Posts
Also try a non-three way bulb in the socket. It should work on some of the settings to show power is not an issue.
Old 05-08-19, 12:11 PM
A
Thanks very much everyone.
i put in a 100 bulb and it works fine. maybe we will leave it that way.
