Electrical tape or not
Old 05-12-19, 02:59 PM
C
Need a consensus. When replacing a 15 amp wall outlet, should you wrap the outlet terminals with electrical tape.
Old 05-12-19, 03:20 PM
A
Received 274 Upvotes on 250 Posts
Tape is not customarily used. The wiring relies on its insulation, careful bending and placement, and its rigidity so as not to touch in the wrong places.
Old 05-12-19, 03:25 PM
Tolyn Ironhand's Avatar
Received 867 Upvotes on 730 Posts
If you are installing the device in a plastic box there is no point. I do not normally tape my devices, even when installing in a metal box. However, there is nothing wrong with doing it. It is just another step and is personal preference.
Old 05-12-19, 03:33 PM
L
Received 199 Upvotes on 170 Posts
Not necessary.
I only do it if the device (outlet or switch) needs to be left outside of the junction box for drywall installation.
I sometimes do it when metal junction box is used, especially when the box is tight.
Old 05-13-19, 12:02 AM
Received 1,262 Upvotes on 1,203 Posts
Should you? No, not really necessary.
Can you? Sure, it's your house, go ahead - you're not going to hurt anything.
FWIW, none of the ones I have installed in my house are taped.
Old 05-15-19, 04:32 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
FWIW, it's a real PIA when you start to remove a duplex receptacle that was taped when it was installed.
Old 05-15-19, 05:20 PM
E
Received 17 Upvotes on 16 Posts
For the reason CasualJoe mentions, in the rare cases I feel the need to tape receptacles or switches I fold back a very small portion at the end of the tape. That makes it much easier for the next guy to remove. And the next guy might be me!
The times I may use tape are when a metal mud ring or switch box is set back close to the 1/4" maximum from the surface, which brings the device terminals up close to the metal opening.
Old 05-15-19, 05:29 PM
T
Received 190 Upvotes on 166 Posts
As Casual Joe mentions, mastic from old tape is extremely messy. For that very reason I always used White or Grey tape for anything permanent. Still messy but nowhere near as objectionable if it gets transferred somewhere unintended.
Old 05-16-19, 04:36 AM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
Agree with others. I'm not sure where this idea that tape was needed with with wire nuts. My old man use to use tape also. Never understood why.
