GFCI Help!!!
Old 06-22-19, 02:25 PM
D
GFCI Help!!!
I'm trying to install a GFCI outlet under my sink for my garbage disposal and dishwasher. There is a white, black, and red wire. I attached the black and red wire to the gold screw line side and attached the white wire on the silver screw line side. Now the outlets work but the switch to the garbage disposal does not. The garbage disposal just stays on......any thoughts?
Old 06-22-19, 03:10 PM
A
Received 48 Votes on 43 Posts
It depends on how things were wired. If both dishwasher and GD were plugged in to the same duplex receptacle then it's not going to work. A GFCI has both top and bottom outlets connected together so can't be half switched. The easiest thing to do in those cases is to use a GFCI circuit breaker in the electrical panel.
Old 06-22-19, 04:27 PM
Geochurchi's Avatar
Received 88 Votes on 83 Posts
Hi, how was the GD switched before?
Geo
Old 06-22-19, 05:00 PM
D
There is a switch that controls the G/D. Regular outlet underneath the sink. I was told that there has to be a GFCI
Old 06-22-19, 05:13 PM
Geochurchi's Avatar
Unless it was an inspector requiring it it’s not required.
Geo
Old 06-24-19, 10:47 AM
Z
Received 157 Votes on 139 Posts
As Astuff mentioned:
If you look closely at the old receptacle, you'll see the little brass tab connecting the top hot/brass screw to the bottom screw was removed. This allowed one receptacle to be switched for the GD and the other to be always on for the DW.
A GFI receptacle can't be half-switched, so you'll either need a GFI circuit breaker in your panel, or use a double-size/gang box and have two GFI receptacles, one for the GD and one for the DW. (or a regular for the DW if it's allowed)
