Electrical Wiring Diagram Question
Received 0 Votes
Hi All:
I had a fairly simple question about planning wiring for my basement. I have 1 outlet that I would like to feed 2 others due to how the room is shaped.
Can I wire them in a pigtail to feed those other 2 outlets or do I need to go from outlet to outlet.
Here is a quick snip of what I wanted to do.
Here is the layout in case the photo doesnt go through.
Panel -> Outlet 1 -> Outlet 2 -> Outlet 3
-> Outlet 4
Outlet 2 feeds both Outlet 3 & Outlet 4
-> Outlet 4
It's more than the amount of connectors. A box is rated by internal cubic inches. Each box has a size listed with it. Each wire has a value. If you use a two gang deep box you'll be fine.
Many like and swear by push-in connectors so it's more of a personal thing.
My opinion.... i will not use push in connectors. For recessed fixtures they are barely passable.
For heavy circuits.... no way.
As an electrician we are used to 5, 6, 7 #12's in a gray wirenut.
Also as an electrician.... there would be no tee tapping. It would be one receptacle to another.
Received 0 Votes
Appreciate the insight. I understand the opinion on the push connects by why the opinion on the tee tapping as you refer to it. Just curious as to the reasoning on that.
There is no reason that the wiring cannot be T instead of linear. Whichever way make sense can be used.
The Ideal push in connectors have be very reliable for me with zero callbacks. The clear shell lets you see the wire is fully inserted.
