Wiring needs for EV
Old 07-30-19, 11:20 AM
L
Received 10 Upvotes on 10 Posts
Wiring needs for EV
My carport is wired for a 240 volt heater that was removed and the wiring capped. The wire is 10-2 with ground and was previously attached to a 30 amp double pole circuit. Will the 10-2 be sufficient for a home charger for an EV if I choose to buy one of these cars?
Thanks.
Old 07-30-19, 11:53 AM
I
Received 45 Upvotes on 43 Posts
It will be sufficient for a charger up to 30A @ 240V (7200W).
joed voted this post useful.
Old 07-30-19, 01:23 PM
T
Received 74 Upvotes on 69 Posts
EV chargers are a rapidly changing landscape. Some parking lot chargers are now 50kW and 30 cents per minute. Most homes won't support 204 Amps to the garage!
