Reload this Page >
3/4" Raintight Compression Connector with Extra Long Threads?
Old 09-01-19, 09:27 AM
D
Received 1 Upvote on 1 Post
I got a "standard" 3/4" Raintight Compression Connector from a big box sore.Unfortunately, the thread is not long enough to go though my shell, and reducing washers. I beleive the thread is about 3/8" long.
I found this:
https://www.bptfittings.com/store/3-...g-threads.html
Is this a standard or rare special order part?
Old 09-02-19, 05:14 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
What kind of box are you using?
Geo
Old 09-02-19, 05:44 AM
Tolyn Ironhand's Avatar
Received 705 Upvotes on 598 Posts
You could extend it using a chase nipple from the inside of the box and a short threaded coupling to connect between the chase nipple and connector.
Example: https://www.garvinindustries.com/fit...xoCG-YQAvD_BwE
Old 09-02-19, 06:13 AM
D
Received 9 Upvotes on 8 Posts
In 45 years in the trade I have never seen one with extra long threads. I would guess a wholesale house COULD order a box but your going to pay for the box and any special shipping.
Cut the conduit back, use a standard connector, then a rigid coupling and a piece of 3/4 all thread pipe for the connection. I am sure you know this, reducing washers are not waterproof.
Old 09-02-19, 12:26 PM
D
@Tolyn Ironhand. I think this works.
Actually, I need a similar solution for attaching a 90 degree flex connector. It is above the garage ceiling and needs to clear drywall.
