single-pole switch replacement with 3-way. Unconventional suggestions needed
Received 0 Votes
I have a single pole switch with 4 lights, that I want to replace with a 3-way switch. Power currently runs to the switch. I don't have a way (without drilling a lot of holes, which is really not an option) to run 14/3 wire to the desired location for the 2nd switch. Is it possible to add the other 3-way switch to the end of the light run without rewiring all the lights with 14/3. What would that wiring scenario look like? If not feasible, what are my other options?
You cannot run the cable from the second switch to a different light in the chain of lights interconnectd with 14-2 cable..
Look into an electronic wireless 3 way switching kit. Example: Skylink cat. no. SK-8. The remote switch for the second locaton would be battery powered. You would replace the existing first switch with the electronic 3 way load switch that comes in the kit.
Zorfdt voted this post useful.
That Skylink piece is a good price point. I use the Lutron Caseta switch and the Maestro dimmer with the Pico remote switch. The Lutron system runs appox $65. You can get it in wifi for around $100.
