Can I swap a 4 prong dryer plug for a 3 prong plug?
Old 09-18-19, 10:16 AM
P
New dryer has 4 prongs, new older home has a 3 prong receptacle and I can't afford $1,000 to have the 3 converted to a 4. Looking for alternatives. Heard it was safe to take dryer back to a 3 prong cord and plug. Can anyone share your expertise and let me know if I'm on the right track here?
Thank you for your help.
Old 09-18-19, 10:29 AM
Received 251 Votes on 221 Posts
Your dryer manual will have the direction for installing a three prong plug/cord.
Yes it is safe.
If you haven't already done it I would first check the wiring in the dryer receptacle and see if it has four wires and can be converted to a four prong receptacle.
Old 09-19-19, 09:51 AM
Received 1,121 Votes on 1,041 Posts
Welcome to the forums.
At one time it was code acceptable. Is it safe....... yes and no. As long as all three wires coming from the panel remain connected.... it's safe. If the neutral should open..... it's no longer safe.
This is the main reason for switching appliances over to 4 wires..... a safety ground.
Your dryer should have listed the 4 to 3 wire conversion in the manual.
If not.... post the model number for detailed help.
Old 09-19-19, 10:51 AM
Received 157 Votes on 144 Posts
Yes you can.
The only difference is that you have to connect the dryer's frame/body to the white Neutral.
Often there is already a ground strap in the unit but it will be disconnected and the earth ground wire of the 4 prong line cord connects to the frame.
Old 09-20-19, 08:27 AM
CasualJoe's Avatar
Received 87 Votes on 77 Posts
New electric dryers and ranges do not come with a cord of any type (never have), someone had to make the call to install a 4-wire cord/plug. If by new you meant you just purchased a brand new dryer, I'd call the appliance dealer back and tell them they have a problem, it should be their responsibility to change the dryer back to a 3-wire cord/plug.
Old 10-02-19, 07:23 AM
P
Was able to get 4 prong dryer down to a 3 and it's working
Thank you for the responses, they were very helpful. I was able to take the dryer back to a 3 prong cord and ground it with the white neutral wire. A little nervous on the first run, but all went smoothly.
I appreciate those of you who took time to offer your expertise and advise.
Thank you.
