Wired smoke detectors in Georgia
Old 10-30-19, 02:18 PM
B
Doing renovation in Georgia so I have to install wired interconnected smoke detectors in all bedrooms . Does code require a separate breaker circuit, or can jump off a hot wire?
Old 10-30-19, 04:05 PM
Received 3,983 Upvotes on 3,575 Posts
The code does not require a separate breaker and actually prefers it not to be in a residential application. You should connect them to a lighting circuit as opposed to a general receptacle circuit. The reason is you'll notice the lights off/dead and know a breaker was tripped or turned off.
CasualJoe voted this post useful.
Old 10-30-19, 05:24 PM
pcboss's Avatar
Received 195 Upvotes on 171 Posts
Check with your local building officials. Some areas require a dedicated smoke alarm circuit with a breaker lock.
Old 10-30-19, 06:09 PM
B
I'm in Cobb County. I have left messages but can't seem to get any return call.
