New meter box size?
New meter box size?
Hey all,
I'm installing a meter box on an existing steel building. It will feed a 100A breaker box in the shop at first. Later on it will feed an additional 200A breaker box for a trailer on a second loop from the meter box. What size meter box do I need to use?
Thanks!
Thanks!
If I use a 200A meter box and use feed thru lugs on a 100A breaker box, does the main breaker affect the power thru the lugs to the 200A breaker box? Also, if the 100A and 200A breaker boxes are fed from a 200A meter box, is that per code?
