Installing a Shallow Outlet Box
Old 02-04-23, 04:33 PM
G
Gen
Gen is offline
Received 16 Upvotes on 11 Posts
We have a proposed short wall at a property that they want to make as narrow as possible, but want an outlet also. My question what is the minimum wall depth needed for the 2 inch box in the pic? Can the inner wall space also simply be 2 inches or do we need a little deeper to slide this kind of box in place? Thanks!
Old 02-04-23, 05:53 PM
pcboss's Avatar
Received 177 Upvotes on 155 Posts
That looks like an old work box. If so the depth needed includes the depth of the finish like drywall.
Old 02-04-23, 06:43 PM
P
Received 247 Upvotes on 211 Posts
That box is made to work in wall cavity where 2X4's are laid flat with 1/2" drywall. It's a tight fit with the wall cavity only being 1.5" deep.
Old 02-04-23, 07:55 PM
L
Received 195 Upvotes on 167 Posts
If it is new wall, use new work box instead.
You can use this box, with 1/2" mud ring.
https://www.homedepot.com/p/Carlon-2...CARR/100113827
and
https://www.homedepot.com/p/Carlon-1...-CAR/202077390
This will give you more room, and fits in 1.5" space.
You can use metal junction box of same style as well.
Old 02-05-23, 01:30 AM
A
Received 149 Upvotes on 124 Posts
That side-car box in the picture is an old work box like stated.
It is a pest to install if the wall surface is too thick.
If the wall is open I would go with lambition's suggestion using a new work box instead.
Old 02-05-23, 09:59 AM
G
Gen
Gen is offline
Thanks for all the replies. I think I will go with Lambition's suggestion for the plastic box and mud ring. Also I like AFJES nick name of side-car box. Is that a commonly spoken nick name for the old work box that I pictured? My own nick name for that is sidewinder,.
Old 02-06-23, 01:23 AM
A
That is the name I have heard out in the field and some products do even specify the name "Side-Car" such as this item here. There are several different styles of them; new and old work.
The type in your post #1 is good however, it is very difficult to install in an existing wall where the wall covering is thicker (I think up to 1/2" only). Hard to explain but I have come across it a few times in the field. If new sheet rock is being placed ontop of old sheet rock that box more than likely won't fit.
