Humidity control in waterproof box.
Old 10-15-23, 08:33 AM
E
Received 5 Upvotes on 5 Posts
So I ended up shorting out an amplifier and a wifi receiver mounted in an outdoor box because I didnít know I should pack the incoming conduits with silicone and the heat from the electronics condensed enough water to short it out. Oops. So Iím replacing the hardware and will now seal the incoming conduits with silicone, but id like to add a dissecant just in case. Would silica gel work for this (I noticed thatís whatís packed in security camera domes) ? If so how much should I use. The box is 30x20x10cm and the electronics consume 85w.
Old 10-15-23, 02:19 PM
Received 3,983 Upvotes on 3,575 Posts
You can't run electronics.... like a receiver... in a sealed box.
CircuitBreaker voted this post useful.
Old 10-16-23, 05:29 AM
L
Received 201 Upvotes on 172 Posts
It is best to make ventilation holes at the bottom and cover with screen or sponge to keep bugs out.
avoid inserting wires on top to keep water out. Seal it with silicone if you don't have a choice.
Also, make drip loop on wire just before entering the box to keep large amount of water from hitting against penetration.
