Damp environment?
Old 04-03-24, 03:48 PM
C
Received 351 Upvotes on 294 Posts
Damp environment?
I am extending a 15 A circuit in my basement by adding 2 additional receptacles. I'm tapping off a 15 A lighting fixture. The wiring will be exposed atop a 2X4 runner. My intentions were to use a length of 12/2 armored cable that I had lying around from another project. Then I read that armored cable is not suitable for a damp environment.
What is a damp environment? My basement stays fairly dry, typically around 50% RH or less. I have never seen it higher than 55%.
Part of my problem is that we have a new inspector. The old guy, recently retired, knew what was important and what wasn't. I heard that the new guy is a nitpicker. Is there somewhere that defines damp environment as it applies to armored cable?
Old 04-03-24, 05:36 PM
P
Received 278 Upvotes on 235 Posts
I would not consider your basement as a damp location per the nec.
cwbuff voted this post useful.
Old 04-04-24, 05:24 AM
P
Received 2,309 Upvotes on 2,054 Posts
Don't forget to GFCI protect the outlets.
Old 04-04-24, 06:05 AM
C
The plan is a GFI to protect me.
CircuitBreaker voted this post useful.
