Four way wiring modification
Old 04-28-24, 08:14 PM
Received 9 Upvotes on 7 Posts
I have a set of lights on a 4 way wiring.
One three way switch, one four way switch, and a second three way switch. However, the due to some reconfiguration the four way switch is now inside a closet and no longer needed.
I would like to remove the 4 way switch and change that switch box into a junction box instead.
Right now coming into the 4 way switch box are 4 conductors in an EMT conduit. Two black conductors two red conductors going to the 4 way switch. Red conductor #1 goes to a brass screw, red conductor #2 goes to a black screw, black conductor #1 goes to a brass screw, black conductor #2 goes to a black screw.
Once I removed the 4 way switch, how would I connect the 2 red and 2 black conductors such that the remaining 3 way switch will work as a normal three way?
Top Answer
04-29-24, 02:38 PM
AllanJ
AllanJ is online now
Received 287 Upvotes on 262 Posts
The two traveler wires coming from one 3 way to the 4 way will almost certainly be different colors.
The two traveler wires coming from the other 3 way to the 4 way will almost certainly be different colors.
(You can verify the preceding 2 sentences by examining the 3 way switches.)
Fact: Either traveler wire from one 3 way may be connected to either wire coming from the other 3 way and the remianing two loose wires, coming from different switches, may then be connected together.
So of the 4 loose wires, if two are the same, connect them together. Then connect the other 2 loose wires together.
Old 04-28-24, 11:15 PM
L
Received 44 Upvotes on 36 Posts
The brass screw wires connect to one 3 way switch and the black screw wires connect to the other 3 way switch. You might want to label the pairs somehow before removing the switch. Anyway, red to red, black to black will work.
Old 04-29-24, 04:11 AM
B
Received 314 Upvotes on 277 Posts
#1 and #2 in post 1 are not helpful unless the 2 associated wires come from the same switch. Post 2 contains clarification.
Old 04-29-24, 05:35 AM
Received 521 Upvotes on 426 Posts
To eliminate the switch connect the two reds together and the two blacks together and put a blank cover on the box.
MiamiCuse voted this post useful.
Old 04-29-24, 06:55 AM
I apologize. I really do not know how the conductors are paired because they came to this 4-way switch from the same 3/4" EMT conduit (amongst other conductors) so the traveler pairs probably met up somewhere in a ceiling fixture box above before coming down to the wall switch. It may be save to assume the travelers are paired as red/black but no idea which red is paired with which black.
Old 04-29-24, 01:29 PM
Received 4,103 Upvotes on 3,685 Posts
You could always see what's on the other three way switches for traveler colors but typically you would connect red to red and black to black.
Old 04-29-24, 02:38 PM
A
Gen, MiamiCuse voted this post useful.
Old 05-06-24, 10:54 PM
Just an update - connecting red to red and black to black at what used to be the 4 way switch location works! Thanks!
