How to get electricity to Pergola
Old 05-09-24, 11:57 PM
P
Iím trying to add ceiling lights to our covered pergola (has roof panels). The problem is that itís 3 feet away from building. Canít go from ground because itís all concrete. What would be the best way to get a cable over, a rigid conduit? See pic
Old 05-10-24, 05:08 AM
T
Received 214 Upvotes on 188 Posts
I'm not normally a fan of them, but I would use battery powered lights. I can't think of a code compliant way to bring an aerial cable to the pergola that wouldn't be plug ugly.
Old 05-10-24, 05:31 AM
Tolyn Ironhand's Avatar
Received 917 Upvotes on 775 Posts
I would agree with ThisOldMan. I think your best option would be to install a receptacle on the house and then plug in a cord as needed.
Old 05-10-24, 08:04 AM
the_tow_guy's Avatar
Received 266 Upvotes on 217 Posts
Solar lights maybe, with collector on the pergola roof?
Old 05-10-24, 11:29 AM
P
Thanks, Iíll probably just do the plug route then.
Old 05-11-24, 10:57 AM
Z
Received 135 Upvotes on 126 Posts
Could you add a beam like in the picture above, and hide a run of conduit on top - or maybe sandwiched in a split beam? Seems like you could make it look pretty good (I just added a flag hanging on it) but to others maybe not so nice - lol. I'm not an electrical guy so I don't know whether that would violate electrical code.
But it seems like it would be safe.
OK - just thought. building code would also be a factor.
Old 05-17-24, 05:17 PM
Technically UF cable is required to be supported every 4 1/2' so you could swag the cable between both buildings. But as OldMan pointed out it would not look very good.
Old 05-18-24, 10:36 AM
Z
OK - I'm really losing it. I swore I posted this pic in my previous post. But obviously not.
No pic - I guess I'm at some kind of limit. Oh well. Not a good HMI IMHO.
Old 05-18-24, 11:33 AM
W
Received 36 Upvotes on 30 Posts
Several threads now where people have not been able to post their pictures or the pictures are posted but they don't appear. A site issue?
I don't know what your light requirements are, but you can get battery operated LEDs with remote control.
