quiet warmth - fault when stepped on
Old 05-21-24, 07:19 PM
N
I have recently installed a second room with quietwarmth, but this one has a total of 11 mats, but 3 of them have a the same problem. When I step on it or there is weight on the wire led that connects to the mat, the thermostat will trip with a gfci fault. I can trigger this time over time again on command. Has anyone else had this problem, thoughts on why?
Old 05-22-24, 04:04 AM
B
Received 322 Upvotes on 284 Posts
Defective mat. Does GFI outlet or thermostat trip?
Old 05-22-24, 02:29 PM
Received 4,156 Upvotes on 3,732 Posts
Welcome to the forums.
Poor installation.
Not following the install directions.... exactly.
These floor heating thermostats have a GFI built in.
Many offer a higher current trip rating to reduce nuisance tripping.
You have 11 mats. How do you know which ones have the fault ?
What is the mat installed over..... cement/concrete ?
A GFI trip is from the heating element to ground.
