Sparking angle grinder
Received 0 Votes
Hello everyone,
My grinder (which is a few month old. no warranty) started sparking more than usual so I replaced the carbon brushes and they were almost totally gone, one of them actually flipped on its side. But even with the new brushes, the grinder still sparks a LOT more than normal. I disassembled it and cleaned the body thoroughly with the air blower, and cleaned the commutator with a toothbrush along with the blower, but that didn't do much help and I'm running out of ideas. Could this be caused by lack of lubricant? Is there a better cleaning technique in this case?
Any idea guys?
Thanks in advance.
ps/ there are no problems with the wires like exposed one or anything
Any idea guys?
Thanks in advance.
There can be multiple reasons for excessive sparking. This page details some reasons.
I know my grandpa used to clean out the commutator with a hacksaw blade and lightly go over the grooves with a triangle file.
If you replaced the brushes but not the holders, I would say that the holders are damaged, at least on one side, allowing the brush to chatter and vibrate.
I'm not sure how you were able to use up the brushes in a couple months. My Metabo has seen 10+ years of commercial use and it's still going on it's original brushes. I would look closely as XSleeper mentioned. There may be some other problem causing the brushes to wear so quickly.
Received 0 Votes
Thanks guys for your input, and thanks for the helpful link XSleeper.
This grinder actually I got for only $30. I got it cause I needed a variable speed grinder and it was the only one nearby.
The brushed did ware off fast, but this is actually my firs time dealing with cheaper power tool and a variable speed grinder so I didn't know what to expect. I also did use it quite a lot in the short time I had it.
I once bought a cheap grinder ($10 Chicago Electric) in a pinch when I needed one to grind some concrete on a job... it literally lasted 10 seconds once I plugged it in and put it on the concrete. When it comes to tools, cheap no-name tools are usually just that. Some work good, but it seems a high percentage are lemons that need to be returned or exchanged for a refund.
I have 2 Bosch grinders I have used and abused... no complaints.
