Frozen 1/2-Inch chuck
Old 10-10-16, 12:09 PM
L
I have a new-to-me craftsman model 113.24590 drill press manufactured in 1967. The chuck is rusty and frozen. It is a morse tapered chuck. I used CRC Knock 'er loose penetrant on the chuck and the chuck collar 3 days ago. One day after treatment, I loosened the chuck collar using the chuck key handle but cannot get the chuck off the spindle. I was not able to move the chuck mechanism with the key. Since I could not remove the frozen chuck, I placed #2 diesel into a small can and submersed the spindle-attached chuck into the diesel. It soaked for 2 days. The chuck is still frozen. Please suggest a chuck removal technique. Please suggest a better chuck penetrant than diesel. I have other solvents that I can mix to your specifications. Thanks
Old 10-10-16, 12:22 PM
Received 4,155 Upvotes on 3,731 Posts
For soaking metal I use Liquid Wrench liquid. Comes in quarts and gallons.
As far as removing the chuck.... that can be a challenge.
Is there/did you remove the screw in the center of the chuck ? Could be a reverse thread.
Old 10-10-16, 01:49 PM
Rough Rooster's Avatar
Received 16 Upvotes on 12 Posts
Lower spindle, look above chuck for a vertically slotted area. This slot will need a chuck wedge hammered into it to loosen the Morse taper fit of chuck to spindle.
Easy with a wedge, almost impossible without it.
Happy hammering,
RR
Old 10-10-16, 03:52 PM
Received 129 Upvotes on 114 Posts
Did you look it up to see if the chuck is mounted to a separate mandrel, or is the morses taper built into the chuck that locks into the spindle?
Old 10-10-16, 04:57 PM
Looked this model up and discovered I gave you wrong instructions. The chuck has outside threads at top and a locking collar on spindle that secures it in place.
Go to this website and download the 12 page pdf file for your machine.
http://www.vintagemachinery.org/pubs/222/4824.pdf
Good luck.
RR
