Router Chatter
Old 10-22-16, 07:38 PM
W
Router Chatter
I have a PC 3 1/4 hp router mounted in a router table. When routing an edge with a 1/4" Roman Ogee bit I am getting occasional chatter. The bit is nearly new and the work piece is securely held down. The routed edge shows no evidence of chatter. Any ideas as to the cause?
Old 10-22-16, 08:01 PM
XSleeper's Avatar
Received 901 Votes on 827 Posts
If you bit is clean and your bearing is ok, try adjusting the speed of the router.
Old 10-23-16, 03:30 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
3 things I can think of. Speed of bit, speed of feed , to big of cut, 1/4 ogee should be ok. If hard wood I usually try to do it in 2 cuts. little bit at a time.
Old 10-23-16, 10:07 AM
C
Received 2 Votes on 2 Posts
Are you routing in the correct direction? For normal cuts you want the cutting edge to be pulling the work into the bearing, and not do a climb cut:
Routers Go Left | How To Use A Router
Old 10-23-16, 11:09 AM
W
Received 32 Votes on 29 Posts
Routing
Routing with the grain works better than routing against the grain.
Old 10-24-16, 04:30 AM
the_tow_guy's Avatar
Received 67 Votes on 56 Posts
Carbide bit or plain steel?
