need high rpm's for buffing but hand drills doesn't do the trick
Old 04-10-17, 07:42 PM
V
What I need is a drill with a very high rpm because to shine jewelry I need as many rpm's as I can get. I have a dremel drill and a bigger hand drill but it doesn't have the rpm's that I need. Most jewelers use a table grinder machine with a big buffing wheel on it but I don't have the room for that. Any suggestions of any tool that can give high rpm's.
Old 04-10-17, 07:55 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
Maybe look into an air polisher.
Old 04-10-17, 07:59 PM
Received 1,113 Votes on 1,033 Posts
I would think that a bench mounted or table top polisher would be required.
It must be pretty hard to polish jewelry while holding the polisher.
My first thought was a shoe polishing machine.
Professional Electric Shoe Polisher Machine | eBay
Old 04-10-17, 08:01 PM
XSleeper's Avatar
Dental tools and jewelry tools are quite similar.
Old 04-10-17, 08:07 PM
That's true. Especially tools from Foredom.
Old 04-11-17, 07:50 AM
B
Received 37 Votes on 34 Posts
A rotozip turns up to a rather high speed. Check to see if they offer any attachments for buffing.
Bud
Old 04-11-17, 08:12 AM
Received 94 Votes on 83 Posts
Just what kind of RPM do you need? I have a Bosch drill that will do 2,000 but that's about the limit I've ever seen.
Old 04-12-17, 05:58 PM
A cuttout tool (essentially a jumbo rotary tool) has a 30k rpm and enough torque to handle a small buffing wheel. Most have a 1/4in chuck but if you want something larger you can get an adapter (mine was made to attach a suppressor to a .22 barrel) and attach a 1/2 chuck to that. You'd probably want something to mount it in if you go that route.
Old 04-12-17, 06:38 PM
Tolyn Ironhand's Avatar
Received 209 Votes on 185 Posts
You say your using a Dremel "drill", but I find Dremel rotary tools (model 4000) have speeds up to 35,000 RPMs
Old 04-12-17, 07:35 PM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
I bought a buffer like this from Harbor Freight when it was on sale for about $39.00 and for what it is works exceptionally well.
