Tool identification please?? Take 2
Old 10-17-17, 06:36 PM
C
Both pictures include tools that were together, not sure if they belong together or not though.....
Anyone know what these are called and/or used for??
Thanks!
Old 10-17-17, 06:59 PM
Rough Rooster's Avatar
Received 13 Votes on 10 Posts
Automotive repair tools. First pic is assorted gear and harmonic balancer/steering wheel pullers.
Second pic is McPherson strut spring compressors. Looks like additional handles for power drill also.
Value new several hundred $$.
RR y
D
The top pic has automotive gear pullers & a steering wheel puller.
The second pic is a spring compressor.
Was I right on the first post where I said that it was a hole puncher?
Old 10-17-17, 07:04 PM
C
Thanks! Any idea of what is each of their value second hand?
And are those nuts and bolts part of the tools or are they just mixed in there?
Also: Hole puncher made sense to me - thanks!
Old 10-17-17, 11:04 PM
C
Old 10-17-17, 11:20 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Pretty much, yeah. As you can see, used value isn't much. Maybe $50 on a good day for everything. MAYBE....on a GOOD day.
Old 10-18-17, 04:08 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
Bolts with long black bolt go with steering wheel puller. 4 slotted piece, black bolt should screw in center.
Old 10-18-17, 06:25 AM
D
Second hand tools won't bring more than a few dollars. A friend of mine sells used tools at a flea market. Every week he complains.
Old 10-18-17, 06:45 PM
C
Thanks everyone! Have another!!
Old 10-18-17, 06:49 PM
C
How about this stuff?? (last time!!) It is hard to tell, but the socket is like 1/2 drive on one end and a threaded female connection on the other - anyone know what that is for? and what the other stuff is??
Thanks again everyone....
Old 10-18-17, 08:44 PM
Crimping pliers for boot clamp on front wheel drive CV joint. Far right is a tool for aligning clutch disc when reassembling clutch. Can't really see the other tools , but next to far right looks like a circlip expander for removing inner tie rods and/or axles.
Another group of automotive repair tools.
RR
Old 10-18-17, 09:58 PM
C
Awesome! thanks again!! the 2nd and 4th are heavy and solid - like a solid rod with an end like a nail.....
Old 10-22-17, 10:54 AM
C
Received 20 Votes on 17 Posts
In photo 2 those handle-looking deals look like the handle to a 4 1/2 in. angle grinder.
