Can my Angle Grinder accept 4-1/2 in. Diamond Turbo Cup Wheel?
Old 10-28-17, 07:20 PM
Q
Hello all,
I purchased HF 4-1/2 in. Diamond Turbo Cup Wheel Warrior® - Item#61419 and my Angle Grinder is Hitachi G12SR3 4-1/2".
I need to install the Turbo Cup Wheel to my grinder but I just realize it may not fit my machine.
Can someone take a look the attached pictures and tell me whether or not the wheel fits my grinder?
After installing the cup wheel, I am not able to install the Outer Flange to lock the wheel.
The HF cup wheel does come with a place where I can tight it up but I am not sure that is safe.
Thank you
Old 10-28-17, 08:04 PM
XSleeper's Avatar
Received 848 Votes on 777 Posts
You need to take the bottom washer off. The cup wheel just screws on. Don't over tighten it either or you may have a hard time getting it off. Just snug it with your hand... not as tight as possible either.
Old 10-28-17, 08:16 PM
Q
Hello,
I just followed your instruction and installed the cup wheel.
May you take one more look and help check whether I did it right?
Thank you
Old 10-28-17, 08:24 PM
XSleeper's Avatar
You don't need a nut on top. The cup wheel just screws on. You spin the cup wheel on just like I said... and don't over tighten it with your hand.
Old 10-28-17, 08:32 PM
Q
Hello XSleeper,
Thank you very much for your kindness.
Old 10-29-17, 06:10 AM
GregH's Avatar
Super Moderator
Received 47 Votes on 45 Posts
I have a fair amount of grinding to do on a couple of current projects and have never tried that wheel type.
Give us a review of how it works for you.
Old 10-29-17, 11:17 AM
Tolyn Ironhand's Avatar
Received 284 Votes on 248 Posts
I have the same wheel and it worked very well on some concrete work I did. I used it to smooth an opening I made for a door in a garage.
Old 10-29-17, 04:07 PM
Q
yes, it works real well and I like it very much!
Thank you
