Laser Level & Detector
Old 12-18-17, 05:58 AM
Dustin_27's Avatar
I am about to regrade my lawn because of poor drainage. I have a large lawn and I am over using a homemade water level. I have looked into laser levels and detectors but they are very expensive.
Can anyone recommend a brand of laser level & detector for a DIY'er that I might be able to use for other projects around the house that won't break the bank??
Old 12-18-17, 09:03 AM
Marq1's Avatar
Received 1,140 Upvotes on 1,033 Posts
I have used a Fat Max and a tape measure. About the only issue is that you cant do it in bright sunlight but it works fine as the sun starts going down!
They are only about $30.
Old 12-18-17, 10:33 AM
P
Received 1,849 Upvotes on 1,655 Posts
I have a Davis White laser level and detector though I'm not sure if it would fit in your price range. My level has a setting where I can leave the laser on but not rotating and with it not moving you can see the laser dot even in the sun but if it's rotating at a usable speed it's almost invisible during the day, but you can make it work without a detector albeit slow. You could get by with a cheaper unit or even a simple level but you'd be limited to checking elevations in a straight line, then go to the laser and re-position it.
Old 12-18-17, 01:27 PM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
I got one a few years ago from lowes for around 100$ . Here is a quick look at Lowes today
https://www.lowes.com/pl/Laser-level...rm=laser+level
