Help with my Paslode finish nailer
Old 06-03-18, 12:00 PM
Y
have the same problem with Paslode finish nailer and framed nailer. Cleaned and greased put new fuel cells and they donít want to fire. I think thereís a problem with the cell compartment because doesnít want to close right. I tough there were only two sizes of fuel cells. You can here the fan going when I put battery but ones I press down to fire the fuel cell compartment opens. Please help I donít know what am I doing wrong
Old 06-03-18, 12:11 PM
XSleeper's Avatar
Received 1,922 Upvotes on 1,726 Posts
The finish nailer takes a yellow fuel cell... the framing nailer takes a red cell. Could that be part of the problem? Also the older guns were a different size than some of the newer ones.
Old 06-03-18, 01:58 PM
Y
Yes, Iím using yellow for the finish nailer and red for the framing. I only saw those two different at Loweís. Paslode brand and they are supposed to fit both of my nailers. Plus they are just two sizes yellow small, for finish nailer and red bigger size for framing nailer.
Old 06-04-18, 12:21 PM
W
Received 63 Upvotes on 55 Posts
Check the bottom of the fuel cell compartment for foreign objects.
