Air compressor nail gun
Old 05-20-19, 02:29 PM
B
Hey yall, I have a blue hawk 2 gallon air compressor/nail gun. The small gold knob on the bottom that releases pressure has gotten stuck and when I tried to turn it counter clockwise it snapped off. Looked rusted. I released the pressure after using it the last time so Im not sure how this happend, but Any ideas on how to replace or fix this?
Old 05-20-19, 03:02 PM
Received 330 Votes on 293 Posts
Welcome to the forums!
Are you referring to the petcock on the bottom of the tank or is it part of the regulator?
Pics could be helpful - https://www.doityourself.com/forum/e...-pictures.html
Old 05-20-19, 04:51 PM
XSleeper's Avatar
Received 716 Votes on 663 Posts
If there is no longer anything to grab you will need to drill it out and tap new threads. Most petcocks are the same size thread.
Start with a small drill bit and oil... drill directly in the center. Once you get a hole made use progressively bigger bits until you get up to the size of your tap.
Old 05-20-19, 04:58 PM
Tolyn Ironhand's Avatar
Received 223 Votes on 196 Posts
Before drilling, bleed off the air that is in the tank with a spray nozzle.
Old 05-20-19, 05:18 PM
Received 94 Votes on 83 Posts
If you had enough rust for that to break, I would be concerned enough about rust in the tank itself that I think I would just replace the whole compressor.
