Table saw arbor, Has a bit of play.
Old 11-03-19, 12:43 PM
biketrax's Avatar
Received 1 Vote on 1 Post
So I have a bigger Craftsman contractor saw that runs great I keep a nice 10 inch blade on it for most of my heavier cutting. I use a small sears lightweight direct drive saw i keep in a shelter outside for most of everything else. Although it can handle a 10 inch blade i use an 8 inch thinner blade which makes cutting small pieces a bit safer and comfortable. I believe i have heard it said to taming down your saw? However I recently noticed a small bit of play in the arbor. I haven't really did any exploring yet, I thought i would ask if any body knows of an adjustment for that kind of side ways play ?
thanks all
Old 11-03-19, 03:36 PM
XSleeper's Avatar
Received 718 Votes on 664 Posts
There is no adjustment in a bearing that allows end play.
Old 11-03-19, 08:21 PM
GregH's Avatar
Super Moderator
Received 38 Votes on 36 Posts
I agree.
If this is a belt drive saw the arbor bearing would need to be replaced.
Some nearings are permantly pressed into the arbor and some can be replaced.
Just make sure the bearing has not spun in the arbor.
