How to determine the size of FMC
Old 03-19-24, 02:58 PM
D
Hi,
Is there a method to determine the diameter (inside) of a flexible metal conduit? The conduit already has wires of various gauges going through it, and I'd like to pull more wires through it. But I don't know what the diameter of the conduit is, and I need to know so I can calculate the fill ratio with the current wires before pulling more wires.
It looks to be either a 1-1/4" or 1-1/2" FMC. It might even be 2" FMC
So, I took a piece of 12-gauge solid wire and wrapped it around the conduit, marked it where it met, then straighten it out and measured it. The wires measured to about 5-7/8" in length.
Okay, thank you for your input!
Gregory
Old 03-19-24, 03:05 PM
P
Received 2,228 Upvotes on 1,988 Posts
The diameter is the circumference divided by pie. d = c/π Or, you can cheat and use an online calculator.
Old 03-19-24, 05:34 PM
Received 4,051 Upvotes on 3,634 Posts
FMC is sized by inside diameter.
Based on what you posted..... no jacket.... that's 1-1/2" which is roughly 1.75" OD.
2" would be approx 2.2" OD.
Old 03-19-24, 11:22 PM
D
Thank you to both Pilot Dane and PJmax for your input! Using the calculation that Pilot Dane provided, I was able to determine that it is 1-1/2", confirming what PJmax stated (based on my input).
Time for wiring pulling!
