Security camera's
Old 03-16-16, 05:08 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Security camera's
Hi All, looking for suggestions or opinions on security cameras to use on wifi,location for use would be inside.
Old 03-16-16, 05:16 AM
P
Received 1,954 Upvotes on 1,750 Posts
Start by telling us what your goals are? Security? Keep an eye on kids & pets? Or to check on your home while traveling?
Old 03-16-16, 05:20 AM
Norm201's Avatar
Received 694 Upvotes on 617 Posts
Take a look at today's (3-16-20) WOOT.COM
Old 03-16-16, 07:18 AM
Geochurchi's Avatar
Check on the condo while we are up North for 6 months,we will keep minimum internet service.
Old 03-16-16, 09:05 AM
Received 274 Upvotes on 251 Posts
A fair number of people have been happy with the models put out by D-Link, and they are aimed at the DIY market. You can get cheaper, but with video, I can say that cheap cameras generally produce sub-par images: Wi-Fi Cameras | D-Link
Old 03-16-16, 09:47 AM
Shadeladie's Avatar
Super Moderator
Received 367 Upvotes on 296 Posts
MrRon, your link doesn't work. Says too many redirects and the page can't open.
Old 03-16-16, 10:11 AM
Received 3,632 Upvotes on 3,254 Posts
The link works ok for me.
Old 03-16-16, 10:43 AM
Geochurchi's Avatar
Pete, are you using a PC? I can't open it on my IPad, maybe I will try the link on another browser.
Old 03-16-16, 10:46 AM
Shadeladie's Avatar
Super Moderator
OK, yeah, it doesn't work on an IPad. I tried it in a computer with FF, and it works there.
Trying this link: Wi-Fi Cameras | D-Link
ETA: OK, this link should work Geo
Old 03-16-16, 11:00 AM
F
Several years ago I was involved in setting up a hard-wired Lorex system. (https://www.lorextechnology.com/prom...FdKIfgodGBgI4g) and it worked well. It had remote viewing capability as long as the museum director didn't unplug the modem () and I could look at it in real time or review the recordings. The cameras were what I would call medium resolution, definitely better than the images seen on many surveillance systems on the TV news.
(I have no connection whatsoever to Lorex.)
Old 03-16-16, 11:47 AM
Geochurchi's Avatar
I did get to the link,some neat stuff there,that DCS 930L looks interesting I may check it out, I was trying to determine if I get an alert when something comes into view, I believe it does.
Thoughts
Old 03-16-16, 12:03 PM
Most of those ip cameras have some form of motion actuation. The effectiveness varies, but I understand that these are ok.
Old 03-16-16, 03:05 PM
Norm201's Avatar
What kind of dollars are you prepared to spend? That will determine the effectiveness and the quality of the camera. If all you need is a view and an alert of nearby motion then the under $100 units will do. But understand that the quality of the Internet will be your weakest link for both viewing and alerts.
Old 03-16-16, 08:42 PM
E
Received 5 Upvotes on 5 Posts
I have a hikvision wired IP cameras. I'm happy with them other than wishing they were cheaper.
Old 03-18-16, 12:19 PM
D
Hi Geo,
The two most important things are camera quality, of which price is a pretty good indicator of quality, and internet quality (both of these were correctly stated below by Norm201 and MrRonFL).
In addition to DLink mentioned below, I would also recommend Eugenius brand. They have a nice wifi camera that allows access via a mobile app.
Again, just to re-iterate, it is always best to go with higher quality cameras (these typically are more expensive). IPs are great, but cheap IPs can be just as bad as cheap analogs.
Also, if you (or anyone else for that matter) is interested in learning a bit more about WIFI, CNET has a great article on WIFI connections and diagnosing WIFI problems: Diagnosing and addressing Wi-Fi signal quality problems - CNET
Hope that helps!
-Dave
