Replacing front door unit and have a hardwired ADT security alarm
Old 08-06-16, 07:51 AM
Q
I am having someone at Lowes replace my front door unit ehich includes a transom and 2 sidelights. They will remove the alarm from the door but won't reinstall it. How can I do I reinstall it myself? The alarm system was put in as new construction 25 yrs. ago. Thank you!
Old 08-06-16, 08:01 AM
Received 330 Votes on 293 Posts
Welcome to the forums!
Normally the wire is run thru the framing and the top of the door jamb, the sensor is wired in and pushed back into the jamb. The door itself just has a hole drilled with the magnet set into it. I'm not sure how much the transom complicates things.
You'll want the sensor disconnected and the wire pulled out from above, not just cut off.
Those that know more than me should be along later
Old 08-06-16, 09:11 AM
XSleeper's Avatar
Received 720 Votes on 666 Posts
The wire will usually be spliced where it connects to the sensor, so that's the place to cut the line. Save the old magnet and sensor from the old door. It usually takes a 3/8" hole. Im surprised they wont do it, I do this sort of thing all the time since its not a big deal and saves the hassle. It has to be done before the trim goes on.
At a minimum the hole needs to be drilled and the wire stuck through... before they trim the door, that is. Maybe if you ask the installer again he will take pity on you. Its just a matter of cutting the lines and splicing them together again. Best location is top of the door, 2" from the leading edge. If the wire is too short, just extend it to the right location with some doorbell wire, speaker wire, phone wire, etc.
Old 08-06-16, 03:45 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Extra 20$ to installer usually will do wonders.
Old 08-06-16, 09:55 PM
XSleeper's Avatar
I can't remember the last time I got a tip. Does anyone still do that?
Old 08-07-16, 12:04 AM
Received 1,193 Votes on 1,104 Posts
They sure do. Showing a little extra kindness goes a long way.
Most of the door/window guys here won't touch an alarm contact. They may pull it out but not reinstall it. I get called all the time to recontact new doors/windows.
Old 08-07-16, 08:18 AM
Received 103 Votes on 95 Posts
With a door that has a transom and side lights surrounding it, you have to plan this _before_ the door is installed. Usually the only path for wire on a frame like this will be at the bottom, so this has to be done _before_ the door frame is mounted. Usually there is a small groove in the bottom of the framing that you could staple a wire along, and drill up to get to a place you can install your contact low on the strike side. You install the contact and wire and leave enough tail to get into the wall void where your original wiring is.
Yes, it's a pain in the neck, and you will have to placate your door guys who just want to get in and get out without having to wait on any extra steps to hang this door (they are often paid by the job, not the hour).
