Vista 20p users
Old 10-19-16, 11:02 AM
D
Vista 20p users
I have tried to add users above 32 and it beeps a acceptance but the codes do not work. Is there something I need to do with user 33 to allow the hight numbers to work in partition 1
Thanks
Old 10-19-16, 01:29 PM
Received 322 Upvotes on 297 Posts
If your system was originally a Safewatch 3000 model; it may be limited to 32 users, and a single partitions (as if it's a Vista 15p).
Old 10-20-16, 12:45 AM
C
Received 73 Upvotes on 65 Posts
Wow! Did NOT know that about the SW3000--never had the issue come up. Thanks, Ron.
Old 10-20-16, 12:06 PM
D
Ok it was not an ADT system is there some way to see if that is the case shows wa20p 5.2 on the honeywell chip
Old 10-20-16, 04:51 PM
What's the part number printed on the edge of the system board?
Old 10-20-16, 05:30 PM
D
part number
i see two sets of numbers sa5882-5 l l165 w386490 k172 thanks
Old 10-20-16, 09:47 PM
T
Received 2 Upvotes on 2 Posts
For user 33 did you input '[master code]833#3012#' ?
Old 10-21-16, 09:19 AM
D
user 33
I left it alone that may be my mistake I do not have but one partition how would I program 33 input '[master code]833#3012# or do i make the 301# Thanks much
Old 10-21-16, 01:51 PM
Ok, I think I have a more coherent explanation. By default, users 33-49 are assigned to partition 2 (which is why Safewatch versions don't have those upper user codes, since the partition function is disabled).
The command sequence suggested would assign the code to both partition 1 & 2. It wouldn't matter if you didn't have a partition 2, since you have no zones assigned to it. If it's more orderly to you to leave the partition 2 setting out of the sequence, then do so.
User manual page 33: https://www.security.honeywell.com/d...a15p_20pUM.pdf
Old 10-24-16, 06:06 AM
D
users fixed
Thanks for the support after rereading the support messages I found that the upper user numbers needed to be given permission to access partition 1.
All are working now.
