How to add window break sensor to existing house alarm?
Old 11-07-16, 01:35 PM
I have a DSC alarm system and want to install sensors that detect window breakage. Is this possible to diy?
Old 11-07-16, 01:57 PM
XSleeper's Avatar
Received 1,963 Upvotes on 1,760 Posts
You would probably want a wireless sensor mounted on the ceiling of the room. Google DSC wireless glass break sensor.
Old 11-07-16, 02:28 PM
Thank you. Is this something I can install myself or need a pro?
Old 11-07-16, 02:46 PM
Received 315 Upvotes on 290 Posts
What is the model of your DSC system?
Do you already have existing wireless devices?
If you don't have existing wireless capability, do you have an unused hardwired zone?
Do you have the installer code to access system programming?
Old 11-07-16, 02:47 PM
XSleeper's Avatar
It's quite impossible for us to know what type of system you have and what your abilities are. If you can follow directions, try the instructions on this page, which should help you determine if your system is wireless compatible or not, and describes the wiring needed..
Old 11-08-16, 07:14 AM
I'll check on the model and other info tonight but I do have the RFK5500 Keypad.
