GE 60-652-95 Carbon Monoxide Detector
Old 04-22-17, 06:31 PM
A
Hi, so I recently bought a carbon monoxide detector for my home and I followed all the directions and for some reason when I press the TEST/RESET button it supposed to have a continuous tone but the carbon monoxide alarm is beeping intermittently and the red and green lights are flashing. Is it because I have it plugged into a power strip? The power strip is mounted on the wall. Is my CO alarm malfunctioning?
Old 04-22-17, 07:06 PM
C
Received 105 Upvotes on 84 Posts
The power strip should have no impact.
According to the manual, in test mode you will get 4 beeps, 5 second pause, and then 4 beeps again.
Green flashing is normal power mode.
The red will flash with the beeps in test mode.
Are you using this with an alarm panel?
Old 04-22-17, 07:15 PM
A
Well it continuously beeps when I press TEST/RESET. The sound should be a Continuous 85 dBA & 10 ft. Yes, I am using this with my GE Simon 2 security system. I have done a sensor test on it. It passed the minimum transmission beeps witch is 8.
Old 04-23-17, 08:05 AM
A
I have already contacted GE Interlogix about this problem.
Old 04-23-17, 10:44 AM
Received 265 Upvotes on 244 Posts
Based on your description, the test mode is functioning as designed:
https://s3.amazonaws.com/static.inte..._Alarm_Man.pdf
Old 04-23-17, 10:47 AM
A
The Manual that you provided does not match the co detector that I have
Old 04-23-17, 02:21 PM
Try this manual instead (you must have gotten someone's "new old stock" if you have this model): http://www.alarmhow.net/manuals/UTC/...e%20Sensor.pdf
Bear in mind, that these units may be fairly old (CO detectors have about a 6 year life span).
Old 04-23-17, 03:54 PM
A
Yep, that's the one. So what's the latest compatible co detector that can be used with my Simon panel?
Old 04-23-17, 06:38 PM
Old 05-01-17, 09:22 PM
A
Ok, also any newer GE interlogix sensors will work with older GE security systems?
Old 05-02-17, 02:22 AM
For the most part. They haven't made any significant changes in the wireless protocol in a long time.
Old 05-02-17, 06:46 AM
A
I saw some co detectors that said it only works with the Simon XT V 1.4 and higher. Does this mean that they will not work with the Simon 2 or 3 panels?
Old 05-02-17, 05:46 PM
The data sheet from the link above only references "Simon" without specifying any models or versions (which it does do with reference to the Concord system): https://s3.amazonaws.com/static.inte...atasht-web.pdf
Old 05-02-17, 06:50 PM
A
Ok, so I will go ahead and buy that detector that you recommend for my system.
