Resetting fire alarm light so ready light will show
Old 07-18-17, 10:52 AM
A
hi, i hope someone could help. i have a dsc ph2550 system and while it was not armed we had a thunder storm and the phone line went dead and the alarm sounded. after the phone was back on the trouble, memory and fire light were on. *2 ,*3, *4did not fix the issue. on zones were displayed as a problem just the fire light. I even powered down and up the system it did not reset it just keeps beeping. any suggestions?
Old 07-18-17, 12:32 PM
Received 3,485 Upvotes on 3,128 Posts
Welcome to the forums.
Did you power the system down completely..... AC and battery ?
Did you have a lightning strike nearby ?
On a complete power down.... the fire alarm would reset.
Do you see any red lights on.... on any of the heads ?
Old 07-18-17, 07:21 PM
Received 267 Upvotes on 246 Posts
Not a good sign. The PC2550 is a pretty old system; so there's no replacement parts outside of something like an auction site.
If you have fully powered down and restored AC and battery power, it's a pretty good chance the system isn't coming back. Are you sure you are getting power from the wall plug power pack? There are also several fuses on the main board to check.
