DIY Concord 4 Hybrid #80843 Planning DIY install advice
Old 08-17-17, 01:23 PM
B
Hello...
I am a network tech but never installed a security system... I inherited a Interlogix Concord 4 Hybrid Starter kit #80843 and I am planning to install it in my home.
I need a list of compatible devices to purchase
This unit doesn't come with a transformer
I need:
3 basic wired interior motion sensors
10 wireless door/window sensors
Outside siren
Key FOB
3 Wireless smoke sensor
1 Wireless heat sensor
No cellular needs, just want the unit to call me and set off the siren
I am not sure if anything else is required to make this panel wireless
Any advice is appreciated,
Bob
Old 08-17-17, 04:51 PM
Received 130 Votes on 121 Posts
Installer manual: http://site.geoarm.com/pdfs/GE/conco...tall-guide.pdf
Manufacturer's site: Concord 4 | Residential Security | Commercial Security | Interlogix Global Security Products
Between the two, the specifications of all of the compatible components with their proper names and part numbers are available.
Old 09-06-17, 08:07 AM
B
I purchased a wireless receiver #60-764-01-95R-16Z for a Concord 4 Hybrid panel I have…I downloaded the manual and I see the figure for wiring the GND, +12V and BusA & Bus BMy panel only has (1) +12V and BUS A & BUS B connector, and I already have the ATP1000 keypad connected to those connectors…Do I also just connect the Wireless Receiver to the same connectors that the ATP1000 is using?
Old 09-06-17, 11:13 AM
Received 1,513 Votes on 1,399 Posts
Yes.... you can connect both devices to the same four terminals.
This is what happens when you have too many AUX devices.
Old 09-10-17, 07:40 PM
G
You don't need to buy an external receiver...There's already one built into the motherboard
