open door warning
open door warning
Hello,
I have looked through the manual and on-line and can not find an answer to what I thought would be easy. I purchased a property with a SafeWatch Pro 3000 alarm. Every time a door is opened the alarm beeps and says, "Close that door". How do I turn that off? I'd like it to either do nothing or several very quiet beeps.
Thanks,
Larry
Thanks,
Larry
The generic to turn off the chime feature is to enter [user code] + [9]
The specifics depends on the model keypad you have. It sounds like the keypad is a 6160V that someone programmed a custom voice announcement to. Installer manual: http://library.ademconet.com/MWT/fs2/9/5851.PDF
You can turn the voice feature off fairly easily.
Yes, it is a SA6160VPROX-1. I found the [code] + [9] in the manual, but did not try as it only said it turn the chime on/off, it did not say anything about the voice warning. I first have to get the alarm working again, an electrician moved the keypad and now it does not work. Turns out the cat6 cable he used has several wires that are not conducting, so need to fish a new wire. After that, I'll try to turn off the warning.
Thanks,
Larry
Thanks,
Larry
