Use of X-10 Powerhorn on a Simon XTi Panel
I have used the X-10 Powerhorn successfully with a Simon XT panel in the past but have moved and decided the upgrade to the XTi panel Revision "F". I cannot get the X-10 components to work with the XTi panel. I have changed the transformer to Part # 22-129-ITI (I was told this is the same as the 60-913) and plugged the panel and the siren into the same receptacle to avoid the same phase issue.
Can the X-10 siren be used with the Simon XTi panels.
Thanks
Thanks
