"Phone Control Problem" service message on NX-6V2
Old 05-07-18, 08:46 AM
Hi Folks,
System is newly installed in a shop with no POTS line.
NX-595E is installed and working.
Communicator disabled in Phone 1 location. No phone numbers, accounts are programmed. Number of "trys" to dial are all programmed to 0.
We initially programmed the panel to have a phone (set up at a "dummy" location hooked up privately to a computer with a cross cable). When we initially got this Service Message, we hooked up a phone line just to clear the message, and subsequently programmed out all locations that had to do with a POTS line.
When system was installed at its permanent location, and we tested the system by putting it into an alarm, the Service Message "Phone Control Problem" came up and will not clear. The 595E has a "Phone Control Problem" message as well.
1. Is there a Location input we might be missing? Test reports? (Although, we need test reports for the 595 reporting)
2. Do we need to put resistor(s) across the 4 inputs? If so what size- 680 or 3.3?
3. Or should we install a "dummy" RX31X phone module?
This is an "out of town" install, so any help would be SO appreciated!
Thank you!
SugerMom
Old 05-07-18, 11:15 AM
Received 1,176 Votes on 1,090 Posts
Use PSTN for Failover: If IP reporting fails, switch to the alarm panel dialer for backup communication path (only valid when PSTN line is connected).
Looks like in "IP reporting" that the use PSTN for failover choice should not be checked.
Old 05-07-18, 04:51 PM
Received 103 Votes on 95 Posts
Make sure the communicator format (programming location 2) is set to 0, that's actually how you disable the dialer function. Also make sure that the telephone line cut delay is set to 0 in location 40 segment 5.
Old 05-08-18, 12:55 PM
Thanks Mr. Ron! It was the Location 40 Seg 5 that did the trick!
SugarMom
