Simon 2 sensor replacement?
Old 06-02-18, 08:11 AM
Yes, I'm still using an old Simon 2 from the early aughts. Up until a few months ago it was working fine. However, one window sensor keeps false alarming in the middle of the night. I have tried installing a new battery and checked that the window is closed properly, etc. but it keeps happening on same sensor. I can't find anyone selling sensors specifically for Simon 2 (even used) but have seen a couple of posts that suggest a Simon 3 sensor would work. Does anyone know if this is true or knows of a place that might sell used Simon 2 sensors? The system was originally installed by ADT and we have since not renewed the contract and just use the system as a basic break in alarm. Another alternative might be to swap with a sensor from an upstairs window and then bypass that sensor. If I can figure out how to program a bypass...
Old 06-02-18, 11:50 PM
Received 103 Votes on 95 Posts
The current generation of Interlogix transmitters will work just fine with a Simon 2.
https://www.interlogix.com/intrusion...reless-sensing
Old 06-03-18, 05:21 PM
Thanks very much Mr. Ron.
