How do I use wired recessed mag contact with french doors?
I've tried to research this but either I'm using the wrong terminology or doing something else wrong, because I can't find this answer anywhere...
I'm replacing a door with french doors and want to know how to do I wire the magnetic recessed switch? My previous contact was on the outer hinged side, but my new doors are french doors and open in the middle. So how do I install a recessed mag contact? I assume it goes on the top, but if so do I have to drill through the header or is there another way to run the wire?
Thank you!
Thank you!
Yes..... you drill up thru the header and across the framing.
If the wire is currently coming out of the framing in the wrong place...... wait until the new casing is installed and run the wire between the door casing and the framing. There will be shims that you need to carefully work around. Keep the wire away from where the molding will be nailed on.
There is usually plenty of room to run the wire in the rough opening around to the top of the door. And there are stubby contacts that are short enough that it doesn't require any drilling into the header.
Thanks guys!
PJmax, the shims were my concern when I thought about running the wires at the top of the jamb. Can you explain how I do that? Do I just run the wire around the shim? And will this give me a problem installing the trim?
Thanks again!
Thanks again!
