Home security system suggestions
Old 01-28-19, 10:58 PM
I have never bought a home security system and am looking for companies or products to send notifications and start recording video when a gate is opened. I also would like to install multiple cameras and be able to view them on a smartphone or tablet. I have no idea where to start, any input is greatly appreciated.
Old 01-30-19, 05:38 PM
Received 267 Upvotes on 246 Posts
Ok you aren't after a "security system", you want a CCTV/video system.
Here's a link to a pretty good learning page: https://www.supercircuits.com/resources/learn
Old 08-13-19, 12:24 PM
N
Received 20 Upvotes on 18 Posts
MrRonFL is correct based on what I understand from your post.
With a decent CCTV system, you can have inputs and outputs from the NVR/DVR to trigger recording or other functions.
With that being said, I am going to assume you would probably want a motion record more than a gate opening record trigger. This way if the gate isn't opened, there is still recording if motion is picked up. Would also save the labor of running the required cables and sensor installation.
If you are truely looking for a monitored alarm with cameras, something similar to an Alarm.com setup might work for you. You can monitor cameras, your alarm sensors and other home automation from it but it does require a monthly subscription.
I have both systems at my home (NVR recorder with cameras and the Alarm.com monitoring with home automation). It's way overkill but I use install this equipment as a side business.
