Door sensors seem easily defeatable?
Old 04-30-19, 07:40 PM
9
Hey guys, sorry if this has been asked 100 times but I didn’t see it in my search.
Just installed my 3rd system (Vista 20p) and while installing my door sensors (Pre-wired my new house as it was built, now that it’s finished I’m removing the door moldings and accessing the wire that I ran.) As I’m removing the insulation foam and installing the sensors im realizing how easy it would be for someone to remove the molding from the outside and access the wires. I would imagine someone could crimp the wires and shirt the circuit to make an easy connection while it’s armed. Is it really this easy or am I missing something?
If it is that easy does anyone make a foam insulation that is like an armor that I could spray in there to make the wires inaccessible? Or any other options?
Old 04-30-19, 07:50 PM
XSleeper's Avatar
Received 1,714 Upvotes on 1,538 Posts
Someone with a cordless Sawzall could also cut a hole right through your wall, bypass the sensor and walk in... so what's your point?
I think you are overthinking this. Theoretically if someone knew exactly where the sensor was and you left them a ton of wire to pull outside, and if the noise of taking your trim off didn't alert anyone and it was a full moon and they could force your door open despite the locks, then ya, maybe.
Most doors and windows have nail fins, so the wire isn't even accessible from the outside even if the trim is removed.
PJmax voted this post useful.
Old 04-30-19, 07:58 PM
Received 3,422 Upvotes on 3,068 Posts
I agree. There is almost no way to get to the wiring.
Old 05-02-19, 12:40 AM
9
Ok thanks guys. Mine was actually very easy to get at by taking off the outside molding (this was my door going from my house to my garage) once the molding was off I easily accessed the wire. I believe this door is an exterior grade door but hey it may be different from my actual exterior doors.
But yes you’re right, probably over thinking, but maybe I’ll look for some super heavy duty insulation foam I could spray in there to stop such easy access to the wiring.
Old 05-02-19, 05:17 PM
C
Received 69 Upvotes on 63 Posts
Just a caveat, don't do such a good job that you can't access the wiring yourself if you ever need to check or replace the switch. I usually leave about a 4-to-6-inch service loop on each switch/contact to allow for possible future work.
Old 05-03-19, 01:09 PM
9
Definitely will do that! Thank you
