Trouble mapping smoke sensors to Concord 4 system
I had to replace old smoke sensors recently. Bought physically and electronically compatible sensors that combine CO and CO2. The sensors are hardwired and they are in series (4 in total).
Having trouble adding the new sensors. I have the installation manual and the codes. After adding the sensors, the system doesn't capture / register them when I check the "Edit" menu.
Some things I've attempted and may (not) be correct:
thanks for the help
- map as groups 26 (fire) or 34 (CO)
- trip the sensor by pressing the test button once
thanks for the help
Kidde Hardwire Combination Smoke/Carbon Monoxide Detector Alarm with Battery Backup and Voice Warning, Interconnectable - Kidde model KN-COSM-IBA
It's compatible (120V, hardwired) with the system they had installed before.
Does that mean that the original system was never attached to the alarm?
Does it mean that the 4 sensors operate standalone and wouldn't report signals to alarm company?
Yes, if what you replaced were 120v interconnected smoke alarms, they were not connected to the intrusion alarm control.
There _is_ a special relay that some people add to their smoke alarm loops to tie to a system zone; but it's really a bad idea for a number of reasons.
AustinTX360
voted this post useful.
Good to know - surprised installer opted for this arrangement. Fire events wouldn't be reported to alarm company.
Thanks for the insight MrRonFL!
Interconnected smoke alarms are generally required to meet building life safety codes. Security system connected smoke detectors are considered supplemental, and are usually in addition to the legally required devices.
You can install system connected smokes that will meet code, but you need to plan for it early in the building process.
