Question about cellular antennas
Old 07-24-19, 01:52 PM
P
Received 9 Upvotes on 9 Posts
Hey guys,
I have a Vista 20p with a GSMX4G installed with an antenna in the attic. I'm planning to swap the communicator out for a LTE-XV verizon communicator because Verizon gets a better signal than AT&T. My question is, can I use that same antenna with the new LTE communicator just to give it a little extra boost, or are those antennas not interchangeable? Sorry, i don't have the model # for the antenna. The new communicator should work fine without it, but i thought a little extra boost couldn't hurt.
Thanks in advance.
Old 07-24-19, 02:56 PM
P
Received 1,950 Upvotes on 1,746 Posts
It might work but it all depends on the specifics of what you have. I have a repeater at my house with a Yagi antenna in the attic aimed at a cell tower and it handles LTE/CDMA/GSM/UMTS/AWS. I know with my setup a lot depends on the cable connecting the antenna as attenuation at the higher frequencies is quite high so I wouldn't just count on hooking up an antenna as an improvement. Cheap cable or too long a cable and you can loose all the benefit of a remote antenna making reception worse.
PJmax voted this post useful.
Old 07-24-19, 06:51 PM
Received 3,593 Upvotes on 3,222 Posts
If it works fine with its own antenna..... don't extend it. I've found that slightly moving those units is more beneficial than an external antenna. A different story if the unit is in a basement.
Old 07-25-19, 05:43 AM
P
Ok, thanks guys! If the unit works fine without it, and I think it will, i'll just leave it off.
Old 08-10-19, 01:27 AM
Andoy33's Avatar
Received 5 Upvotes on 5 Posts
you will have to update eventually as AT&T just announced that they are shutting down the 3G and HSPA+ 4G network in favor for 4G LTE and their fake 5GE. i believe they are upgrading it one by one and shutting off the 3G and hspa network which will be finished by 2022
Old 08-12-19, 06:03 AM
P
I think you misread my post. LTE is what I was installing, replacing the other communicator. As an update, i decided to simply not use the antenna, as the Verizon LTE communicator received a pretty good signal.
