GE Concord Express keypad broken key replacement
Old 11-26-19, 12:34 PM
T
My "1" key on the GE Concord Express keypad finally died from too much pressing.
(1) is there a way to replace the key?
(2) if not, is there a way to replace the keypad?
(3) if not, how do I replace the whole Concord Express unit?
Thanks!
Old 11-26-19, 01:18 PM
Received 1,204 Votes on 1,114 Posts
Welcome to the forums.
They appear to use several different models.
Is it this one......
A picture would be helpful...... How-to-insert-pictures.
Old 11-26-19, 02:51 PM
T
Yes, that's the one.
Thanks.
Old 11-27-19, 03:15 PM
Received 103 Votes on 95 Posts
The keys are essentially a single sheet of molded silicon, so if the individual key fails, you have to replace the whole assembly.
Any of the following are compatible:
SuperBus 2000 2x16 LCD Touchpad (60-746-01),*
SuperBus 2000 Fixed Display Touchpad (60-820),
SuperBus 2000 2x20 LCD Touchpad (60-803),*
SuperBus 2000 2x20 VFD Touchpad (60-804)*
There is a newer model FTP-100 (600-1020) that is also compatible.
I recommend going with one of the programming model keypads. (MARKED WITH A *)
The problem with Concords, is that they internally supervise the keypad serial number; and if you replace it; you will need programming access to delete the old device from the system.
Installer manual: https://static.interlogix.com/librar...%20REV%20J.pdf
