Motion sensor replacement
Ordered a new motion sensor-ECOLINK- because contractors working on my room broke the other one. Hoe do I get the panel to recognize the new motion sensor? The alarm system is by ADT - SAFEWATCH QUICKCONNECT PLUS.
Welcome to the forums.
I install/service alarm systems.... just not that one.
Many times when a motion detector gets damaged..... it's just the case. In your case if both motion detectors are identical and the original one just had a broken case or mount..... swap the case/cover. This will eliminate any programming changes to be done.
If you need reprogramming instructions.... the forum pro will help you with that.
It's a modified version of the Lynx Plus.
Manual: http://library.ademconet.com/MWT/fs2/6/3139.pdf
http://library.ademconet.com/MWT/fs2/8/3135.PDF
I'm guessing you bought the following: https://discoverecolink.com/product/wst-702/
It is listed as compatible with the wireless for this system, but you will have to go into programming to delete the old one and enroll the new one.
Do you know the installer code for your system? (Not the same as the arm/disarm code).
Since it's an ADT modified model, the default installer code in the manual is _probably_ the correct one.
