Remove Fiberglass Insulation from Windows?
Old 01-20-19, 12:44 PM
Received 1 Upvote on 1 Post
Have some windows with over an inch gap around the sides and they have been packed tight with fiberglass insulation.
Does that have to all be removed before I can use some low expansion type foam? If I push on it there is still room enough for another half inch or more of foam.
Hope that makes sense.
Old 01-20-19, 01:37 PM
Marq1's Avatar
Received 1,103 Upvotes on 1,003 Posts
Either material is fine, or you could fill the void with foam, no wrong method!
Old 01-20-19, 02:13 PM
Great, I'll just push the insulation back and then foam it.
Thanks!
